Viper Model 600 Alarm
eggnest
Posted: August 10, 2005 at 6:21 PM / IP Logged
I purchased an 81 Corvette recently.  It appears to have had (at one time) a car alarm installed.  The alarm is still there, but disconnected.  The black box says "Viper - Auto Security Systems - Model 600".
I have read about the HF and the ESP, and downloaded the installation manuals.  Unfortunately mine does not appear to be either of these models.  Both reference a Primary Harness 12-pin connector, which is the same thing printed on the back of the black box I have, with the exception of position 4... those both say "BLACK/ white"...mine says "gray".  For the Relay Harness, the HF and the ESP show an 8-pin connector.  Mine shows 6 pins (printed on the back) in the following order...a-brown, b-violet, c-blue, d-white, e-violet, f-green.
Does anyone know anything about what I have?  And more importantly, if it's even worth messing with?
Thanks in advance, any advice will be appreciated.
Lowron
Member - Posts: 23
Posted: August 10, 2005 at 10:09 PM / IP Logged
The alarm you have is before the HF and the ESP, even before the 300+. Finding remotes wont be too easy. All viper brains have a lifetime warranty, if you have a good friend that works at a viper dealer, you might be able to get them to do a warrante exchange for a newer model. If you do still have the remotes and the alarm still works, it will probably keep working for a long time, don't wory about messing with it.
