CompuStar CM3000 Q?
Justb683
Posted: August 10, 2005 at 11:41 PM / IP Logged
I have a 2003 Ford Ranger and just installed I Compustar CM3000. I can't seem to keep in running after removing the key. But if you just litely tap the brakes and keep taping them it stays running. All wires seem to be checking out ok. Any ideas?
Platinum - Posts: 12,488
Posted: August 11, 2005 at 12:02 AM / IP Logged
I'm assuming that this is a manual transmission vehicle if you want the car to stay running ? Or are you trying to use the TURBO mode on the system ?
Justb683
Posted: August 12, 2005 at 5:06 PM / IP Logged
Yes it is a M/T. I am try to get it to remote start but nothing. I have tried the tach wire at the coil it work for about a day then now nothing, try to repress the black button on the side parking light flash 3 times. Tested the wire it is getting about 5.7 volts. Know any thing?
