Alarm going off while driving?
bdl666
Silver - Posts: 330
Posted: August 16, 2005 at 4:47 PM / IP Logged
I've had 2 complaints about Audiovox remote/starter combos
going off while driving. The fist one was an APS-785 and the second an APS-786t. I've installed a lot of this units   ,
this are the only two times I've heard of this happening.
One was about 2 years ago(the 785) and one just this week(the 786t). Both of the owners claim that they were driving when all of the sudden the alarm starts going off. In both cases after checking all the connections I couln't get the units to do it again.
I think the problem is on the remote because the only way I can get the alarm to go off with the engine running and the key on the ignition is by using the panic function.
Has anyone ever heard of this happening with this Audiovox units?
swamprat323
Gold - Posts: 1,335
Posted: August 16, 2005 at 5:57 PM / IP Logged
can you disable painc while driving or when the igntion is on.
bdl666
Silver - Posts: 330
Posted: August 17, 2005 at 12:49 PM / IP Logged
The panic function can not be disable on this units.
bdl666
Silver - Posts: 330
Posted: August 21, 2005 at 1:11 AM / IP Logged
There's got to be someone here with some experience with this units.
topspoiler
Member - Posts: 29
Posted: August 22, 2005 at 3:42 AM / IP Logged
It might be the igition wire is tap into the wrong wire.
topspoiler
Member - Posts: 29
Posted: August 22, 2005 at 3:46 AM / IP Logged
Sometime one of the remote button is stuck and the alarm thinks that someone is holding on to the button which cost it to panic.
Chris Luongo
Platinum - Posts: 3,746
Posted: August 22, 2005 at 7:19 AM / IP Logged
I've been installing Audiovox for almost four years now, and I've seen this before too.
Ask the customer if the alarm stops after 30 seconds. Also ask them if they noticed the parking lights flashing, or if the heard the brain clicking the parking lights on and off.
If they're getting siren AND parking lights, you know it isn't just the siren wire shorting out to power-----it's most likely the remotes.
bdl666
Silver - Posts: 330
Posted: August 23, 2005 at 2:35 AM / IP Logged
Thanks guys!
It's both the siren and the parking lights, that is why I suspect the remotes. But for some reason they only do it once and it never happens again.
Thursday, September 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
