L.E.D on alarm
02 pimperado
Member - Posts: 21
Posted: August 17, 2005 at 1:29 PM / IP Logged
i have a prestige alarm..with a blue hyper bright led thats mounted in my dash.. call me crazy but i need one in red and i want it as bright as posssible! where do i order? no local shops have them (ive checked 2x) i bought an red led but it was nothing compared to the blue one! please help!
Im OD'in on ADD
mini14
Copper - Posts: 120
Posted: August 17, 2005 at 1:39 PM / IP Logged
search online   they have them everywhere   radioshack might i know if you look harder you will find them
Alpine CDA-9847---Alpine MRP-T220---Eclipse 36201---6.5" Type S Components---6.5" Type S Coaxials---2 10" Thunder6000's Isobaric
02 pimperado
Member - Posts: 21
Posted: August 18, 2005 at 2:02 PM / IP Logged
dang i was lookin for a diredct sigh
Im OD'in on ADD
endless talent
Member - Posts: 45
Posted: August 19, 2005 at 12:27 AM / IP Logged
From my personal experience, a red LED will not be as bright as a blue LED.  It has something to do with the way the diode inside is made to emit it's color---blue and white are typically the brightest, and red and orange tend to be dimmer.  I have installed many different alarm systems, as well as added raw LED's to installs for a wide variety of applications, but have never seen a red LED that will come close in overall brightness and range of visibility as the blue ones.  The red LED that accompanies 2002-up Clifford systems is about the brightest I have seen, and it is a little larger than most, at 13/64" in diameter (once you remove the red plastic cover) as opposed to standard red LED's that are 1/8".  I doubt you'll find much online or otherwise different from what comes with alarms, since most all LED's are made by just a couple of different manufacturers.
bdl666
Silver - Posts: 330
Posted: August 19, 2005 at 2:14 AM / IP Logged
Here you go.
http://www.superbrightleds.com/leds.htm
Look for the highest luminous intensity or mcd.They have a red one that is 12000mcd, but the led itself is clear like the one on your prestige unit.The ones on the Prestige units are 5mm and the ones on DEI units are 3mm. You can use either one it's up to you.
Here are some other places you can get them.
http://www.quickar.com/discrete.php?session=BMgcnRXf
http://www.ledsupply.com/ledsupply/index.html
http://www.eled.com/
http://www.hebeiltd.com.cn/?p=led.diode
http://www.ledtronics.com/datasheets/discrete.htm
http://www.lsdiodes.com/shop/index.php?main_page=index&cPath=1&zenid=12c48c54fc5a15ce2362f188507c6edd
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
