Alarm wiring 2002 Infinity Q45
bakerstep
Posted: August 17, 2005 at 10:40 PM / IP Logged
Please let me have the alarm wiring for the 2002 Infinity Q45
thepencil
Gold - Posts: 1,526
Posted: August 18, 2005 at 10:56 AM / IP Logged
2002 Infinity Q45
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|WHITE/ red           |+ |ignition harness            |
|          STARTER|BLACK/ white        |+ |ignition harness            |
|   SECOND STARTER|red                 |+ |ignition harness            |
|        IGNITION|BLACK/ red           |+ |ignition harness            |
|        ACCESSORY|WHITE/ blue          |+ |ignition harness            |
|       POWER LOCK|gray *1             |- |driver door control unit    |
|     POWER UNLOCK|PURPLE / white *1     |- |driver door control unit    |
|       LOCK MOTOR|lt. green           |   |driver door control unit    |
|     UNLOCK MOTOR|brown               |   |driver door control unit    |
|    DISARM DEFEAT|brown               |   |driver kick panel to rear   |
| PARKING LIGHTS +|RED / yellow          |   |fusebox in DKP,wht 4 pin plg|
| PARKING LIGHTS -|lt. GREEN/ black     |   |pin 11 @ BCM in driver kick |
|       HEADLIGHTS|RED / yellow          |- |pin 5 @ BCM in driver kick |
|     DOOR TRIGGER|*2                  |- |BCM in driver kick panel    |
| DOME SUPERVISION|comes on with unlock|   |                            |
| TRUNK/HATCH PIN|pink/blue           |- |pin 146 @ BCM in driver kick|
|        HOOD PIN|lt. GREEN/ black     |- |pin 122 @ BCM in driver kick|
|TRNK/HTCH RELEASE|yellow/red *3       |- |pin 64 @ BCM in driver kick |
| FCTRY ALARM ARM|arms with lock      |   |                            |
|FCTRY ALRM DISARM|disarms with unlock |   |                            |
|       TACHOMETER|WHITE/ green        |   |pin 38 @ ECM *4             |
|      SPEED SENSE|PURPLE / white        |   |pin 49 @ BCM in driver kick |
|       BRAKE WIRE|RED / white           |+ |brake pedal switch          |
|     HORN TRIGGER|GREEN / WHITE        |- |pin 127 @ BCM in driver kick|
|           WIPERS|blu/yel(L),blu/wht(H|+ |steering column             |
| LF WINDOW UP/DN|blu/red - blu/wht   |A |driver door control unit    |
| RF WINDOW UP/DN|blu/red - blu/wht   |A |passenger door control unit |
| LR WINDOW UP/DN|blu/red - blu/wht   |A |rear LH door control unit   |
| RR WINDOW UP/DN|blu/red - blu/wht   |A |rear RH door control unit   |
| SUN RF OPN/CLOSE|not recommended     |   |                            |
|        RADIO 12V|lt. blue            |+ |radio                      |
|     RADIO GROUND|                    |   |                            |
|     RADIO SWITCH|blue/orange        |+ |radio                      |
| RADIO ILLUMINATE|RED / blue            |+ |radio                      |
|    POWER ANTENNA|pink/blue           |+ |radio                      |
|       LF SPEAKER|BOSE speaker amp    |   |                            |
|       RF SPEAKER|under rear deck     |   |                            |
|       LR SPEAKER|                    |   |                            |
|       RR SPEAKER|                    |   |                            |
Notes:
NOTE: This vehicle has an immobilizer system that needs to be bypassed when adding remote start. Use DEI part number 555U. *1 Meter the wires while turning the key in the driver door key cylinder. Unlock requires a double pulse. *2 The driver door trigger is WHITE/ red in pin 142, the front passenger door is WHITE/ green in pin 37, the left rear door is white in pin 33, and the right rear door is WHITE/ blue in pin 143. Use all four and diode isolate each. *3 The fuel door release is yellow/black in the passenger kick panel in the harness that runs to the rear. It is a high current negative trigger. *4 The ECM is behind the glove box.
Be careful whose advice you buy, but be patient with those who supply it.Alarm wiring 2002 Infinity Q45 -- posted image.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
