Subwoofer Comparison
2000Hondaciv
Posted: August 18, 2005 at 12:59 AM / IP Logged
This is my first time posting, but i read the website all the time. So I work at a pretty high end car audio place and I'm getting ready to put a system in my 2000 Honda Civic EX Coupe. The amp I will be running will be a Diamond D9800.2 which is 800 x 1 watts RMS when bidged at 4 ohms and they only recommend a 4 ohm load. I will have a high output alt. and upgaded battery and all that. When it comes to subs, I want to have 2 tens. One thing I am worried about is not having enough power. The subs I want to do is either the Diamond D910D4 or the Eclipse SW9102. I am open to any comments to help me pick my woofers. Thank you in advance.
haemphyst
Platinum - Posts: 5,059
Posted: August 18, 2005 at 1:02 AM / IP Logged
I'd go with the Diamond, NOT because I like the Diamond more than the Eclipse - I don't, but having HAD a SW9102, I can tell you they WAY more power than that... I was running one (ONE) with the Eclipse DA7232 bad boy digital amp... Close to 3KW into 4 ohms. It liked that kind of power...
