2005 Honda Civic Ignition Harness
Inallalone
Member - Posts: 10
Posted: August 19, 2005 at 10:28 AM / IP Logged
Can I get the wiring for the ignition harness for a '05 Honda Civic
inallalone
thepencil
Gold - Posts: 1,526
Posted: August 19, 2005 at 1:33 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2005 /
12volts white (40A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter N/A
Ignition BLACK / YELLOW   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red   +   ignition harness
Second Accessory WHITE/ red   +   ignition harness
Be careful whose advice you buy, but be patient with those who supply it.2005 Honda Civic Ignition Harness - Last Post -- posted image.
Inallalone
Member - Posts: 10
Posted: August 19, 2005 at 3:31 PM / IP Logged
I found it through searching the forums, but thank you anyways
inallalone
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
