1995 M3 alarm install???
carguy411
Silver - Posts: 683
Posted: December 03, 2002 at 4:25 PM / IP Logged
anyone have any info on this car.
how dificult is it t o install a basic alarm with door locks, ignition,etc
thanks
securinu
Silver - Posts: 772
Posted: December 03, 2002 at 6:18 PM / IP Logged
BMW factory security connector
BMW 3, 5 and 7 series for 1992 to 1998 have a pre-wired factory security connector that can be useful when adding
after-market accessories such as alarms and keyless entry systems. On the 3 series this connector can be found behind
the glovebox near the center console. On the 5 series it can be found either in the same location as the 3 series, or
under the back seat near the battery. On the 7 series this connector can be found near the brake pedal under the
passenger side dash. The layout for this connector is as follows:
PIN FUNCTION WIRE COLOR POLARITY
1. 12 Volts constant RED / gray +
2. Ignition PURPLE / white –
3. Ground Brown -
4. Drivers door trigger BROWN / gray -
5. Passenger door trigger BROWN / blue -
6. Rear door trigger BROWN / purple -
7. Horn trigger BLACK/ blue +
8. NOT USED
9. Lock trigger* WHITE/ red +
10. Unlock trigger* Blue/red +
11. Trunk trigger BROWN / white -
12. NOT USED
* These wires must be tested with all the doors closed or the doorlocks will not respond.
carguy411
Silver - Posts: 683
Posted: December 03, 2002 at 11:20 PM / IP Logged
ok kool thansk for the info.
i thought bmw had that but i usually thought it was in the trunk i guess depends on the model
is it a difficult car to install on. or just  like a normal install, beside the security connector . i wont get any supprises right?
also is that right for the ignition polarity (-) negative for ignition thats weird!!!
let me know thanks again
carguy411
Silver - Posts: 683
Posted: December 04, 2002 at 9:07 AM / IP Logged
also can you explain a little more if you know abou the starter wire for the ignition kill. its under the hood. is it hard to get to please let me klnow
thanks
carguy411
Silver - Posts: 683
Posted: December 04, 2002 at 10:58 AM / IP Logged
oh also i was thjnking of getting the Alpine MRD-M500  as an amp instead of my ua acoustic amp
carguy411
Silver - Posts: 683
Posted: December 04, 2002 at 11:00 AM / IP Logged
sorry put it on the wrong post
Friday, November 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
