99 integra no constant
ohyyoy
Posted: August 24, 2005 at 11:48 PM / IP Logged
i hooked up my new alpine 9847 hu up to my ls integra. my car was broken into and they cut the harness.but anyways i installed tbuhe deck and i cant get a constant. the diagram said that wht/blue is constant but it doesnt work. my pre-set cant be saved. what i did was touch the ignition to the "constant" and i turned on the clock. so i wired the power and ignition from the deck to the ignition wire since i couldnt find the constant. am i going to have to wire a new constant?and also the clock is wired to the ignition so it resets also. what can i connect that up to so that it works properly? thank you.
raydawg357
Silver - Posts: 769
Posted: August 25, 2005 at 1:07 PM / IP Logged
check your fuses under the hood and under the dash
Do it right the first time
5150azn
Silver - Posts: 584
Posted: August 25, 2005 at 1:27 PM / IP Logged
Yep it's the one under the hood
Tell the Snap-On guy I'm not here!
jstruckman
Copper - Posts: 465
Posted: August 25, 2005 at 5:19 PM / IP Logged
If all else, wire it directly to the battery. Just make sure to fuse it if that ends up being the case.
Jazzy
auex
Platinum - Posts: 5,041
Posted: August 25, 2005 at 5:33 PM / IP Logged
7.5A fuse under the hood, labeled backup. This is also the fuse for your ecu so replace it.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
chrisAWD
Copper - Posts: 61
Posted: August 25, 2005 at 8:28 PM / IP Logged
second that, first thing to check on any civic/teg
car 1 = alpine 9807, mtx 404+mtx 311d, polk speakers, kappa 10"
car 2 = pioneer 7700, kicker 400x1, kicker 60x4, 10"compvr x2, kappa speakers
chrisAWD
Copper - Posts: 61
