92 Tempo, command start
RavnKing
Member - Posts: 9
Posted: September 05, 2005 at 8:53 PM / IP Logged
I am looking at installing a command start into my wifes 92 Ford Tempo, and wanted to see if anyone here had a list of the wire color coding?  I really want to get this done for her as a surprise so if anyone can help out that would be great.  Thanks in advance.
Cheers,
Ravn
Quando Omni Flunkus Moritati
(When All Else Fails, Play Dead)
RavnKing
Member - Posts: 9
Posted: September 05, 2005 at 9:10 PM / IP Logged
Sweet, I did not come up with anything in my search.  Thanks for that.  I will now be able to get this done this upcoming weekend.
Cheers,
Ravn
RavnKing
Member - Posts: 9
Posted: October 07, 2005 at 10:36 AM / IP Logged
Does anyone know where abouts I would find the Tan / YELLOW tach wire?  Is it under the hood, if so where would it be.  It is the only connection that I cannot seem to find on this darn thing to this point and from what I understand it is something that you cannot do without installing.  Thanks.
Cheers
mo12v
Posted: October 07, 2005 at 11:59 AM / IP Logged
Tach SignalTAN/YEL OR WHT/PINKIGNITION CONTROL MODULE *
* Ignition Control Module (ICM) Located On Distributor. TAN / YELLOW At Coil On Driver Front Of Engine Can Also Be Used.
MO
