Noise from recent install
ciscored
Member - Posts: 8
Posted: September 08, 2005 at 6:05 PM / IP Logged
Hey guys. I just finished an install for a buddy of mine in his 02 Civic and something happened that I've never encountered before. The following components were what was installed:
1.Pioneer DEH- P80        2.Polk 6.5 componets(front),        3.Polk 5.25 components(rear),        4. Autotek 4ch amp,        5.Kicker 12" L5 + Kciker kx600.1 amp        6. Tsunami 2.0 Farad Cap
After completing the install, everything was working just fine. Then after 3 days of driving around with the new system and everything working fine, out of nowhere this really bad engine noise started up that I can't get to go away. It's a combination of whine plus very soft "popping".
I did the install the way I always do, power wires+remote-turn-on along passenger side and rca's + speaker wires down the middle. The deck was installed using a harness. I made a single ground connection(4 ga wire) to the car and fed the amps + cap through a distro. block .  The only troubleshooting I've done is relocate the ground location(if you're familiar with a 4 door civic,  I placed it right behind the back seat as well where the rear seat belts are attached to the car) and there was no change what's so ever. If I unplug all the rca's the noise goes away(not sure what this tells me). What other things can I try?? I'm going to borrow another amp to rule out "bad amps" as the possible cause. Any suggestions would be greatly appreciated. TIA
I would have posted this in the "Ground Q/A forum" but seems like nobody posts there anymore.....
DYohn
Platinum - Posts: 10,741
Posted: September 08, 2005 at 6:19 PM / IP Logged
General troubleshooting 101: when something was "working fine" and then "stops working" one of two things has happened.  Either something was changed (in which case this is where you begin looking) or something broke.  In your case, assuming nothing was changed, the two most likely things to have broken are the amp and/or the head unit.  Your idea to swap amps is a good place to start.
kgerry
Platinum - Posts: 3,455
Posted: September 09, 2005 at 5:55 PM / IP Logged
this is often the results of ground foils burning open in the audio stage of one of the components... this may require swapping of items to try to narrow down which is the culprit component, which is usually the HU.... try another HU if possible... or try grounding the shield of the RCA to see if this changes the problem at all... if it does, take it to a qualified tech to be looked at.....
it's often tough to try to troubleshoot ground issues online... you just have to try this, try that, etc....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
