2003 plymouth neon disarm?
Alpine Guy
Platinum - Posts: 2,478
Posted: September 10, 2005 at 10:23 AM / IP Logged
I just had a customer call back about a 2003 NEON i put a starter/alarm into.  He says when you start it it dosn't start, but the vehicle honks a few times.  It worked fine when i installed it.  It does not have a factory alarm, nor does it have factory door locks.  It used a bypass box to bypass the imobilizer system.  What could possibly be going wrong?  Is there some other disarm wire i missed that possibly enables after the vehicle sits off for a while?
mo12v
Posted: September 10, 2005 at 1:48 PM / IP Logged
Did this car have the GRAY Key?
MO
Alpine Guy
Posted: September 10, 2005 at 4:05 PM / IP Logged
Definately did.
mo12v
Posted: September 10, 2005 at 4:55 PM / IP Logged
I think the Customer should bring it back in and duplicate the problem.
I have seen ( not specifically Neon ) some cars come with Manual Door Locks WITH Security System.
Sounds like the Bypass may have moved
MO
Alpine Guy
Posted: September 10, 2005 at 4:57 PM / IP Logged
any idea what the factory disarm wire may be?
mo12v
Posted: September 10, 2005 at 5:05 PM / IP Logged
No INFO on 2003 Plymouth NEON
This is for 2003 Dodge NEON:
OEM Alarm ArmLT GREEN/ ORANGEDRIVER KICK PANEL **
OEM Alarm DisarmSINGLE WIRE SYSTEMSAME AS ARM **
* RKE Located At Access Panel At Top Of Dash ** LT GREEN/ ORANGE Wire Must Receive A Ground Pulse Through A 2.7K Ohm Resistor To ARM/LOCK And A Ground Pulse Through A 7.5K Ohm Resistor TO DISARM, Double Pulse Will UNLOCK
MO
Alpine Guy
Posted: September 10, 2005 at 6:38 PM / IP Logged
thanks  for your help.
Alpine Guy
Posted: September 11, 2005 at 12:32 PM / IP Logged
Turns out its just a dead cell in his battery, and a dead battery in his remote.   Some people are just morons I tell ya.
Thanks for your help
mo12v
Posted: September 11, 2005 at 6:40 PM / IP Logged
It's great when the customer shows you ............. & U know better
MO
