Horn chirp
Mexbaja
Member - Posts: 29
Posted: May 06, 2002 at 7:30 PM / IP Logged
I just made the horn honk when I arm the alarm
but the honk is to long How can I make the horn chirp???
or one second horn honk
thank's
sERgIO
the12volt
Administrator - Posts: 3,959
Posted: May 07, 2002 at 9:33 AM / IP Logged
Hi Mexbaja, how did you tie in your horn? Did you use a dedicated horn output from the alarm or did you use the siren lead? If you used the siren lead, how did you connect it?
the12volt
Mexbaja
Member - Posts: 29
Posted: May 07, 2002 at 6:55 PM / IP Logged
Hi  jeff
do u remember that I asked u about the horn..!!??
it's an impulse res-r
u told me to convert the samall amp ground to strong ground to make the horn work using a relay
I made work but only honk when I use the remote starter but not when I arm and desarm the system, what I did is Jump the lock wire to the horn wire that goes to the relay
when I arm the system the horn honk but to long I just want to make honk like those factory keyless on newer cars
sERgIO
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
