Window Module
Hickmanae3
Copper - Posts: 67
Posted: September 14, 2005 at 3:21 PM / IP Logged
how do i wire an relay to act as a two window up and down module.
No security system can beat the tow truck :(
mo12v
Posted: September 14, 2005 at 3:37 PM / IP Logged
One Relay won't do it..........Depending on Polarity, i.e. Reversal Rest @ Ground, Postive Output, Negative Output, etc.
Your money would probably be well spent on a Window Module for your application, unless you feel Relay-getic............
By the time you figure your Relays, wire them, & install, U could have a Module on and be using it
MO
Hickmanae3
Copper - Posts: 67
Posted: September 14, 2005 at 11:10 PM / IP Logged
well yes im felign relay gentic so ill just take that chance for wiring them up. I have a ford explorere 97 so which way would i set up the relay
