window module/ (-) 500mA Armed output
alienjj
Posted: September 16, 2005 at 4:17 PM / IP Logged
I'm currently trying to use the Directed 529t window module in my car. But I do not have an alarm system. I also am connecting it to only 1 window, so that i can control both up and down operation of it. The problem is that "one touch" open and closing only works with the alarm inputs on the module, which are (-) 500mA Armed output, and (-) 200mA Channel 2 Output coming from the alarm. What I want to do is somehow create these outputs and then connect them to two seperate momentary switches, to control the window module. So how do I create (-) 500mA Armed output, and (-) 200mA Channel 2 Output, without an alarm?
iskidoo
Silver - Posts: 1,048
Posted: September 16, 2005 at 4:49 PM / IP Logged
That is just a ground pulse. Hook one side of the momentary to ground and the other to the input trigger wire. Do the same with each switch.
Steve G
alienjj
Posted: September 16, 2005 at 7:15 PM / IP Logged
would the momentary switch have to be normally open, or normally closed?
iskidoo
Posted: September 16, 2005 at 7:30 PM / IP Logged
normally open. to test the functionality before you install the push button just touch the trigger wire to the vehicle ground and the windows should roll up. Then touch the other wire to ground and the windows should roll down.
Steve G
