99 Beetle, Roll Down and Roll Up Windows
mrsparky637
Member - Posts: 47
Posted: September 17, 2005 at 1:43 PM / IP Logged
Would it be possible to open and close windows when I lock and unlock doors by holding down on the lock and unlock button? If so, how would I have to wire that?
mrsparky637
blazeronspokes
Copper - Posts: 102
Posted: September 17, 2005 at 2:23 PM / IP Logged
dei power window module.
gus1
Gold - Posts: 1,013
Posted: September 18, 2005 at 5:43 PM / IP Logged
use extra Aux. on the unit, set up for validity (on as long as button is pressed) and tie into the same wires in the door that you used for doorlocks.
Gus
Chris Luongo
Platinum - Posts: 3,746
Posted: September 19, 2005 at 7:43 AM / IP Logged
Do the windows go up and down when you hold the key in the driver's door?
If so, you can duplicate this from your alarm fairly easily, with just one cheap relay.
Go to the Security forum at www.carsound.com, and do a search for "nissan"--- there, you will find instructions on how to do this for Nissans----your car's wiring colors will be different of course, but the procedure should be the same.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
