Clifford Rsx 3.5
junior537
Posted: September 18, 2005 at 10:28 PM / IP Logged
 I just bought me a clifford Rsx 3.5 and I was woundering if anyone had a wiring Diagram for a 1999 Honda civic Lx. I installed two older model clifford alarms myself but i need help on this one. I would have let them install it but they wanted an arm and a leg any help would be appreciated.Clifford Rsx 3.5 -- posted image.
LesLala
mrcllusb
Copper - Posts: 489
Posted: September 18, 2005 at 11:36 PM / IP Logged
Just remember that if you install it urself,that clifford will not honor their theft gaunrantee..
"ole blake"
redpeppers
Silver - Posts: 483
Posted: September 19, 2005 at 10:50 PM / IP Logged
here goes.........
12volts white   +  ignition harness
Starter BLACK/ white   +  ignition harness or
Notes: In 6 pin white plug behind fuse box
Second Starter
Ignition BLACK / YELLOW   +  ignition harness
Second Ignition yellow   +  ignition harness
Third Ignition
Accessory WHITE/ black   +  ignition harness
Second Accessory
Keysense
Power Lock GREEN / WHITE   -  keyless entry module
Notes: The keyless entry module is white in color, and located in the drivers kick panel.
Power Unlock GREEN/ orange   -  keyless entry module
Lock Motor WHITE/ red    drivers kick panel
Unlock Motor blue/red    drivers kick panel
Parking Lights+ RED / black    keyless entry module
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger lt. GREEN/ red   -  OEM alarm plug
Notes: The OEM alarm plug is to the right side of the steering column. The plug is green.
Dome Supervision same as doors
Trunk/Hatch Pin blue/black   -  OEM alarm plug
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer blue    test connector
Notes: Drivers side fire wall under hood in a 2 pin plug
Wait to start
Brake Wire GREEN / WHITE   +  brake switch
Parking Brake
Horn Trigger gray   -  OEM alarm plug
Memory Seat 1
Memory Seat 2
Memory Seat 3
Where theres is a wire there's a way.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
