Square Port addition
Walkercustoms
Copper - Posts: 219
Posted: September 20, 2005 at 11:08 AM / IP Logged
Ok, I still am having a hard time with this square port conversion or addition of another sub.  Ok, let say you have 1 10in sub and port dimensions are (square) 2.5x5x12.5,  Now I know the length stays the same but, lets say I want to add two more subs how do I determin the length and width of the port for the additional subs?
stevdart
Platinum - Posts: 5,816
Posted: September 21, 2005 at 10:10 PM / IP Logged
You can separate each sub into its own chamber and each one will have a port at exactly the size of the first one.  Or, you can start getting aquainted with a box-building program and use it for your designs.  WinISD Pro and Unibox are two free ones that I use.
BTW, the length of a port only "stays the same" if you are converting round to square or vise versa.  When you add subs to a common chamber, all dimensions will change to get the same tuning frequency and control port noise.
forbidden
Platinum - Posts: 5,354
Posted: September 22, 2005 at 1:29 PM / IP Logged
I would go the 3 chamber route as well, makes for a stronger box and if you lose one sub to having the magic smoke that makes it work escape, you can still continue to use the other two.
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
