Source for fuse bypass?
63expert
Posted: September 21, 2005 at 11:23 AM / IP Logged
I have a special application that I install on a fairly regular basis that requires me to bypass spade style fuses.  By the word 'bypass' I mean that I remove the fuse, then replace it with two wires, one being the source (positive) and the other to the device.
The way that I have been doing this currently is that I take a regular fuse, intentionaly blow the fuse, then solder two wires to the back of the fuse and then heat shrink the entire package and replace the original fuse with my blown, modified version.
Recently, I was discussing the way that I do this with another tech and he told me that he had seen connectors made specifically for this same thing.  Try as I might, I haven't been able to find these anywhere.  My application is fairly specific and I can't think of any reason that someone would want to do this on any regular basis enough for someone to actually produce this item.
Figured that if anyone knew about these, it would be on here.  Any suggestions?
63Expert
sneakycyber
Silver - Posts: 413
Posted: September 21, 2005 at 1:03 PM / IP Logged
Neva seen 'em but someone here may have
Thursday, September 11, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
