2000 plymouth Neon Wireing Diagram
X1Lightning
Posted: December 06, 2002 at 6:36 AM / IP Logged
Anyone know where i can find a wireing diagram for a 2000 neon?
jrilla
Gold - Posts: 1,498
Posted: December 06, 2002 at 8:30 AM / IP Logged
If you need a wire diagram you can click on site search at the bottom of the column on the left and search for your car.
2000 Plymouth Neon Security Information
Constant 12V+Pink/Black or Red Ignition Switch Harness
StarterYellow Ignition Switch Harness
IgnitionDark Blue Ignition Switch Harness
Ignition 2BLACK/ Orange Ignition Switch Harness
AccessoryBLACK/ Orange Ignition Switch Harness (Heat/ AC)
TachBLACK/ Gray Coil
Neutral Safety WireYellow (+) Ignition Switch
Brake SwitchWHITE/ Tan Brake Switch
Trunk ReleaseGREEN/ Black (+) Driver's Kick Panel
Trunk PinTan/Black (-) Trunk Light
Parking LightsBLACK / YELLOW (+) Light Switch
Head LampPURPLE / White (+) Light Switch
Factory Disarmw/Locks Arms and Disarm with Locks
Door TriggerLight Blue/Orange Driver's Kick Panel ( all Doors)
Door LockLight Green Single Wire Negative Trigger
Door UnlockLight Green 2 Pulse 1.5K Ohm w/o Keyless Entry
Driver's LockORANGE / Black (+) Driver's Kick Panel
Driver's UnlockPink/Black (+) Driver's Kick Panel
Passenger UnlockPink/Purple (+) Passenger's Kick Panel
Horn WireBLACK/ Red (-) Steering Column
Windows UpLF=Light Blue, RF=BROWN / White
Windows DownLF=WHITE/ Light Blue, RF=PURPLE / White
J Rilla
Owner/Installer
X1Lightning
Posted: December 06, 2002 at 8:32 AM / IP Logged
thanks.. i guess i should have been more clear.. i'm looking for the wireing diagram for the main harness i need to see if there is a differance between the automatic tranny and the manual tranny harness...
