noise problem
aragonhome
Member - Posts: 6
Posted: September 24, 2005 at 2:19 PM / IP Logged
Hi,
I've read in the 'car stereo cookbook' that the solution to my noise problem is...  "capacitor to ground at the alternator output"
However, I don't really know what the heck it's saying...  I have a bit of noise from the stereo that you can hear and it changes slightly with the engine speed.  I guess I'm lucky that I don't have more but I would really like to fix the noise.
Thanks for the help - David
tcss
Silver - Posts: 1,623
Posted: September 24, 2005 at 2:28 PM / IP Logged
What year and make of car is it in? List all of the equipment.
aragonhome
Member - Posts: 6
Posted: September 24, 2005 at 3:18 PM / IP Logged
Hi,
It's in an 05' camry.
Bose amp, bose speakers (taken from an 03' chevy silverado).  The amp has a simple power, ground and a turn on/off wire.
Speakers are connected according to a silverado wiring diagram.
Thanks,
David
tcss
Posted: September 24, 2005 at 5:43 PM / IP Logged
Bose factory systems ( especially the Nissan ones ) are extremely sensitive to input level. It usually falls somewhere between pre amp and speaker level. Your camry's output is likely much higher then what the Bose amp needs. Get a differential converter, two if you want to fade. My favorite is the PIE PDC-LOCv2 but other companies like peripheral, soundgate and blitz make them too.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
