python alarm won't stop
trsturself
Posted: September 28, 2005 at 5:32 PM / IP Logged
I have had this alarm in my cherokee for a couple of years with no problem. I recently installed door lock actuators (not hooked up to the alarm as of yet). After doing this I noticed my alarm was really weak sounding when I'd arm it, and wouldn't sound at all when I disarmed it. Then about a week later, I forgot the alarm was set and opened the door. The alarm went off and wouldn't stop. When I pushed the button on the remote, I could hear a click by the brain, the alarm would beep around 5 times really fast (much faster than normal) and then immediately go full blown without a pause. I tried the valet button with the car on, but it wouldn't do anything either. I had to pull the connector for the main wires out of the "brain" before it would shut off.
I checked the wires near the brain and nothing seems out of place. I also pulled the door locks out of their power source just to see if it made a difference and it didn't.
What are possible causes for this so I have some places to start checking?
trsturself
Posted: September 28, 2005 at 5:36 PM / IP Logged
btw... as soon as i start putting the connector back in the brain it starts going with the 5 beeps -> full blown immediately.
JWorm
Platinum - Posts: 2,208
Posted: September 28, 2005 at 5:56 PM / IP Logged
Sounds like the ground wire from the alarm may have come loose.
trsturself
Posted: September 28, 2005 at 6:10 PM / IP Logged
sorry, the first time i tried to post it, it came back and said it didn't post because the subject was bad or something of the sort. very frustrating since i lost the whole post. i didn't know it actually posted it. sorry again... wasn't intentional.
a loose ground wire... that definitely could've happened. thanks a lot I'll check that!
trsturself
Posted: September 29, 2005 at 6:53 PM / IP Logged
Well the ground wire looked fine.
Any other ideas?
Monday, October 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
