Pioneer avic n2 Bypass
nstlfrk
Member - Posts: 23
Posted: September 29, 2005 at 7:23 PM / IP Logged
For every one that is looking for a bypass for the pioneer models AVIC N2 and d1 you dont need one. After install and the unit is set up and navi is programed just put a toggle switch on the VSS wire this is the pink wire also know as speed sense. The memory in the unit will remember every thing in it. Also dont forget to ground the green brake wire. You will still get the message at the begining saying not to veiw just hit ok it will work fine.
Yes this does stop your speedo and g rating from working in the diagnostic display but you are watching a dvd and when you need the display just turn it back on.        Also it does impare your navi (it will try to do every thing by antenna)but like i said just turn it back on when you need the navi option.
nstlfrk
Member - Posts: 23
Posted: September 30, 2005 at 9:36 AM / IP Logged
UPDATE
the gyros in the unit do catch this and turn the warning on but it is only when there is high acceleration. It turns off by itself right away or you can turn the toggle switch on and off. so the first idea works but not 100%.
