Better sound out of mids
ice8168
Copper - Posts: 52
Posted: October 02, 2005 at 7:34 PM / IP Logged
I have a quick question.  I am about to install a 6.5" and a 4" in the door of my Silverado.  They are both are non-component sets.  Would I get better response out of these speakers if they were in small sealed enclosures.  If so how do I go about sealing small portions of the door?  THe 6.5" is in the frame of the door and the 4" is mounted in the door panel itself.  How much air space would each speaker require?
Blowntweeters
Silver - Posts: 650
Posted: October 02, 2005 at 8:23 PM / IP Logged
i would just dynamat the door panels. keep things simple at first.
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
DYohn
Moderator - Posts: 10,741
Posted: October 03, 2005 at 10:33 AM / IP Logged
Are you trying to create a 3-way system?  What is your crossover setting?
youngone
Silver - Posts: 269
Posted: October 03, 2005 at 4:35 PM / IP Logged
for the tweet you cant do enthing that i know of but for the 6.5 you can use fiberglass and make a little box for them and put alittle poly fill in it . as for building the box it isnt going to have to be big. it depends on how much spac you have to work with. all you have to do is make the actuale box an inch or two wider than the speaker. make the box go all the way to the door panal. you can use fg or mdf. i suggest useing fg becuse it makes a more exact fit on the panal. look at the fiberglass and interier forum to find out how to do it right and fell free to ask Q if you dont get anything. there are Q like yours that are on there you sould be able to find them. good luck
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
Friday, January 2, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
