2006 Civic coupe alarm?
tcss
Silver - Posts: 1,623
Posted: October 04, 2005 at 4:00 PM / IP Logged
Anybody do an alarm in one of these yet? I need the wires.
There is no such thing as free installation!
thepencil
Gold - Posts: 1,526
Posted: October 04, 2005 at 4:11 PM / IP Logged
Doesn't look like much has change other than how it looks. I hope they keep it that way for a while.
DIRECTWIRE™ WIRING INFORMATION - HONDA / CIVIC / 2006 / Remote Start
12volts white (50A)   +   ignition harness
Starter yellow   +   ignition harness
Second Starter N/A
Ignition blue   +   ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory orange   +   ignition harness
Second Accessory red   +   ignition harness
Keysense pink   -   ignition harness
Power Lock green   -   dr kick or MICU, 34 pin plug, pin 28
Notes: The MICU (Multiplex Integrated Control Unit) is part of the fuse/relay box under the driver side dash. It has two plugs on the back of the fuse/relay box.
Power Unlock gray   -   dr kick or MICU, 34 pin plug, pin 27
Lock Motor blue   5wi DKP or fuse box, rear 14 pin plug
Unlock Motor yellow   5wi DKP or fuse box, rear 14 pin plug
Parking Lights+ red   +   dr kick or fuse box, top 42 pin plug
Parking Lights- gray   -   switch or MICU, 20 pin plug, pin 13
Hazards green   +   switch or fuse box, rear 16 pin plug
Turn Signal(L) blue   +   dr kick or fuse box, top 42 pin plug
Turn Signal(R) brown   +   dr kick or fuse box, top 42 pin plug
Reverse Light brown (4dr) or purple (2dr)   +   dr kick or fuse box, top 42 pin plug
Door Trigger see notes   -   ea kick or fuse box, top 42 pin plug
Notes: The LF door is green in pin 37. The RF door is lt. green in pin 3. The LR door is brown in pin 17. The RR door is gray in pin 2. Use all four wires and diode isolate each.
Dome Supervision pink   -   fuse box, rear 8 pin plug
Notes: Also found in a plug attached to the bottom of the fuse box.
Trunk/Hatch Pin blue   -   dr kick or fuse box, top 42 pin plug
Hood Pin lt. blue   -   pin sw or fuse box, mid 21 pin plug
Trunk/Hatch Release green   +   dr kick or fuse box, top 42 pin plug
Power Sliding Door N/A
Factory Alarm Arm orange   -   dr kick or MICU, 34 pin plug, pin 32
Notes: Meter this wire while turning the key in the driver door key cylinder.
Factory Alarm Disarm brown   -   dr kick or MICU, 34 pin plug, pin 31
Disarm No Unlock see factory alarm disarm
Tachometer NOT blk/wht, black or yel/blk   ac   any ignition coil or fuel injector
Wait to start N/A
Brake Wire lt. green   +   switch or fuse box, top 42 pin plug
Parking Brake orange (4dr) or lt. blue (2dr) -   parking brake switch
Horn Trigger orange   -   switch or fuse box, rear 16 pin plug
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: 555U
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models.
Be careful whose advice you buy, but be patient with those who supply it.2006 Civic coupe alarm? -- posted image.
Chris Luongo
Platinum - Posts: 3,746
Posted: October 04, 2005 at 4:14 PM / IP Logged
Just did a little writeup on one over at the carsound.com forums.
The car I worked on was a sedan; I'm not sure if the coupe would be any different.
http://www.carsound.com/cgi-bin/UBB_CGI/ultimatebb.cgi?ubb=get_topic;f=3;t=002677
tcss
Posted: October 04, 2005 at 4:18 PM / IP Logged
Thanks guys
thepencil
Gold - Posts: 1,526
Posted: October 04, 2005 at 4:23 PM / IP Logged
Thank you Chris Luongo for sharing that with us. 2006 Civic coupe alarm? -- posted image.
Sunday, October 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
