Remote Start Engine
patrickminas
Posted: October 10, 2005 at 2:44 AM / IP Logged
I have installed a remote start engine
t starts normally but after few second the starter runs again.
the alarm needs a negative ground (-) when the car starts so the starter will never start when the car is running.
I have a 1989 Mercedes-Benz 300E.
all i need is where to connect the wire (Negative ground when started)
By the way, my alarm has a second option:
i can wrap the same wire around the high tension cable of distributor.
Thanks for your help.
The Peace Maker
mrcllusb
Copper - Posts: 489
Posted: October 10, 2005 at 3:43 AM / IP Logged
What brand alarm is it??
"ole blake"
patrickminas
Posted: October 11, 2005 at 6:50 AM / IP Logged
I dont know what is the brand of the alarm i think its "TOP VENOM ALARM"
i just want to know where to connect the wire
what gives the negative ground when the car start (or positive , i can put a relay)
thanks for your help
The Peace Maker
Satkunas
Copper - Posts: 97
Posted: October 11, 2005 at 5:05 PM / IP Logged
The (-) while running is used as an output, not an input. If it's actually an input then it's probably a very old remote-starter. Ages ago we used to hook them up to a vacuum switch, which would explain why your starter keeps cranking, even after it is running.
Does the remote starter have a tachomoter (pulsed) input?
If not I suggest you purchase a remote-starter that was made after the 80's which has a tachometer input (pulsed). You can try hooking up a vacuum switch, but they can be a real pain to adjust.
If so, forget about that wire and use the tach wire instead.
iskidoo
Silver - Posts: 1,048
Posted: October 11, 2005 at 7:14 PM / IP Logged
It probably is an input but made in Hong Kong or Taiwan or something. The negative input when running is probably a tach wire that got lost in translation. Usually they are referring to hooking the wire to the negative side of the ignition coil. Put up a scan of the wiring diagram if you still aren't sure. We can probably help you decipher it.
Steve G
dualsport
Silver - Posts: 983
Posted: October 11, 2005 at 9:08 PM / IP Logged
If it really is some old system that needs a ground input to tell it to stop cranking, you might try adding a voltage comparator with the threshold set to something like 13.2V or so. When the car runs up and the alternator starts putting out, the voltage will rise above the threshold and the comparator circuit can ground that line as necessary.
During normal starting, the voltage is below the threshold so the RS is enabled to crank.
It's a bit easier to do than put together a tach monitoring circuit. Easier still may be to get an updated RS as mentioned-
dualsport
Silver - Posts: 983
Posted: October 11, 2005 at 9:10 PM / IP Logged
From the description that you can wrap the wire around the spark plug wire, it sounds like it does have a tach monitoring circuit, so you probably need to hook up to a tach line.
dualsport
Silver - Posts: 983
Posted: October 11, 2005 at 9:14 PM / IP Logged
Remind me not to try editing by hitting the back button... Remote Start Engine -- posted image.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
