need 03' chevy wiring diagram
loudnlow
Member - Posts: 13
Posted: December 09, 2002 at 7:58 PM / IP Logged
I was wondering if anyone has a wiring diargram for a 2003  Cheverolet 1500 , and also are there any tricks that have to be done to put a remote start on one??    It seems that most vehicles are needing the immobilizers now.
 Thanx for any info!
securinu
Silver - Posts: 772
Posted: December 09, 2002 at 8:00 PM / IP Logged
passlock2 for remote start   best to use the plgmd databus bypass module
securinu
Silver - Posts: 772
10nesne1
Silver - Posts: 284
Posted: December 10, 2002 at 10:15 AM / IP Logged
Chevrolet
Suburban
2000-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW (18 AWG)
IGNITION SWITCH HARNESS *
Ignition  #1:
PINK (16 AWG)
Ignition #2:
WHITE (18 AWG)
IGNITION SWITCH HARNESS(ECM)
Ignition  #3:
N/A
Accessory:
ORANGE
IGNITION SWITCH HARNESS (HEAT/AC)
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
VIOLET/WHITE
AT PLUG ABOVE VALVE COVER ON DR. SIDE
Parking Lights:
BROWN (+)
12 PIN PLUG IN FUSE PANEL OR AT SWTICH
Headlights:
YELLOW (+)
AT HEALIGHT SWITCH
OEM Alarm  Disarm:
GREEN
IN FLAT CONNECTOR IN DR. KICK PANEL
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This Vehicle Is Equipped With GM's PASSLOCK II Anti-Theft System; See Note #113.
Chevrolet
Suburban
2000-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED (2)
Starter  Kill:
YELLOW (18 AWG)
Ignition  +12 Volts:
PINK (16 AWG)
Dome  Lights/Superv:
WHITE
AT PLUG IN CONVIENENCE CENTER **
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
LT. BLUE
12 PIN PLUG AT FUSE PANEL ON DR. SIDE
Power  Unlock:
WHITE
DRIVER'S KICK PANEL IN BODY CAVITY ***
Trunk  Release:
N/A
Alarm  Input Wire:
WHITE
Notes:
** Convenience Center Is Locate Under Driver's Dash Near Fire Wall (Listen for dome light relay). *** See Note #202 - Positive Pulse Door Lock Diagram.
Hope this wiring diagram would help you.  good luck
