Amp Kick into protect mode
Skyvan
Member - Posts: 8
Posted: October 17, 2005 at 1:20 AM / IP Logged
I finish install all my amp today. about to try it.. but amp won't turn on. When i disconnect the ground wire from the distribution block. The amp kick into protect mode. the funny thing is . there are no ground. how can the amp protect light still on. PLEASE HELP ME. i'am really really tired.
thanks
dwarren
Posted: October 17, 2005 at 1:39 AM / IP Logged
Maybe you should get some rest and look at it when you aren't so tired, maybe try typing when you aren't so tired either.
Skyvan
Member - Posts: 8
Posted: October 17, 2005 at 1:44 AM / IP Logged
thanks
Skyvan
Member - Posts: 8
Posted: October 17, 2005 at 3:39 PM / IP Logged
help any one ?
DYohn
Platinum - Posts: 10,741
Posted: October 17, 2005 at 4:05 PM / IP Logged
Sounds like you have a cheap or defective amplifier that is getting a ground connection through the case.  Either it's broken, or you will end up with ground loop issues that you can never solve.  What's the amp and is it new or a FleaBay special?
Skyvan
Member - Posts: 8
Posted: October 17, 2005 at 8:19 PM / IP Logged
Hi it a new amp. Nakamichi PA-2004. I took it into the house and use the home thingie my brother have. it turn on just fine
