Mazda 3 remote starter and alarm comb
ekdude
Member - Posts: 36
Posted: October 17, 2005 at 3:49 AM / IP Logged
Hello,
i'm just wondering if there's any special procedures or cautions that i need to take before installing an alarm/starter on to this vehicle it's automatic... I know that it is a single wire door lock system.... now how do i connect the relay(s)? what is the numbers for each terminal? and what do you guys know about the 1000 ohm resistor for the foor lock system?
mrcllusb
Copper - Posts: 489
Posted: October 17, 2005 at 5:58 AM / IP Logged
What brand and model alarm is it??
"ole blake"
ekdude
Member - Posts: 36
Posted: October 17, 2005 at 11:47 AM / IP Logged
it is the Autostart Brand
Model # AS 6520 TW
mo12v
Posted: October 17, 2005 at 12:34 PM / IP Logged
Not sure what year??
Some Installers will Direct wire from the R / S Alarm with the 1K Resistor
OR
2 SPDT RELAYS:
LOCK:
PIN 87 = Ground
PIN 30 = 1K ohm Resistor to Vehicles Lt GREEN / Red wire
PIN 85 = Negative Lock Output from AS6520
PIN 86 = Constant 12 volt ( + )
UNLOCK:
PIN 87 = Ground
PIN 30 = to Vehicles Lt GREEN / Red wire
PIN 85 = Negative UNLock Output from AS6520
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=5616&product=Remote%20Start
http://www.directechs.com/directwire/wire_body.asp?action=select&yr=5616&product=Security
MO
