98 Saturn Wagon
tech410r
Member - Posts: 12
Posted: October 17, 2005 at 8:03 PM / IP Logged
I wanted to know if anyone had the wiring guide or diagram for a 1998 Sateurn Station Wagon. Please help, thanks!!!
thepencil
Gold - Posts: 1,526
Posted: October 17, 2005 at 10:11 PM / IP Logged
I don't have one for the station wagon. Hopefully this will help you out.
SATURN SEDAN, COUPE 1998
|       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|red                 |+ |ignition harness or *1      |
|          STARTER|yellow              |+ |ignition harness or *2      |
|        IGNITION|pink               |+ |ignition harness or *1      |
| SECOND IGNITION|                    |   |                            |
|        ACCESSORY|orange              |+ |ignition harness or *1      |
|       POWER LOCK|lt. blue*4          |+ |either kick harness to rear |
|     POWER UNLOCK|white*4             |+ |either kick harness to rear |
| PARKING LIGHTS +|brown               |   |rear of fuse box or *1      |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|blue *9             |- |light switch               |
|     DOOR TRIGGER|white               |- |base of 'B' pillar *3       |
| TRUNK/HATCH PIN|RED / black *5        |- |at light in trunk           |
|TRNK/HTCH RELEASE|blue               |+ |at lever or *6              |
|FCTRY ALRM DISARM|*7                  |   |                            |
|       TACHOMETER|white               |   |ign. module *8              |
|       BRAKE WIRE|lt. blue            |+ |brake pedal switch          |
|     HORN TRIGGER|black               |- |steering column             |
|           WIPERS|                    |   |                            |
| LF WINDOW UP/DN|dk. blue - brown    |A |at master switch            |
| RF WINDOW UP/DN|dk. blu/wht - tan   |A |at master switch            |
| LR WINDOW UP/DN|dk. grn - pur       |A |at master switch            |
| RR WINDOW UP/DN|lt. grn - pur/wht   |A |at master switch            |
Notes:
*1 Fuse boxes located in console and under hood. Wire colors and pin #s are as follows: RED / white constant - console pin F6. Pink ignition - console pin D8. Orange accessory 2 - console pin A6. Brown park lights - console pin F5. Purple (or yellow) starter - underhood pins F6, A2. *2 Can also be found purple at the clutch switch. *3 Also found in taped up harness under ashtray - one of three white wires - test to identify. White at keyless module beats delay. *4 Also at factory keyless module located behind rear passenger seat behind panel. *5 On wagons find dark green at the rear light. *6 Gray at factory keyless module (+). *7 On models with factory security, see direct fax document #1078. *8 Top left rear of motor.   *9 High-current ground for lo beam.
Be careful whose advice you buy, but be patient with those who supply it.98 Saturn Wagon -- posted image.
