2005 Chevy truck
ziggyb222
Silver - Posts: 593
Posted: October 19, 2005 at 5:45 AM / IP Logged
I need to pulse the doorpin on this truck to shut the RAP off after the remote start times out. Where is the best place to do that. There is no under the dash light and the truck is a stripper,no locks or power windows.
Platinum - Posts: 12,488
Posted: October 19, 2005 at 8:57 AM / IP Logged
Go to the BCM for the door trigger wire.On base model trucks, the door trigger wires are in the lt. blue plug at the BCM, pins B4 and A5. The BCM (Body Control Module) is under the driver side dash.  It has 6 plugs in it, the purple plug is on the back. Make sure that you diode isolate ( ONLY IF YOUR USING AN ALARM SYSTEM ) the door trigger wire from the RAP shut down wire. Cathode band facing the door trigger pin ( or away from the BCM ).
