99' dodge avenger
mxxmikexx
Silver - Posts: 796
Posted: December 10, 2002 at 12:50 PM / IP Logged
wondering if anyone has an easier location for the door lock wires, techsoft says RED / blue and BROWN / red in "a harness" behind the glove box. so before i go tearing through "a harness" behing the glove box, maybe someone has  a more specific or easier location for the door lock wires????
thanks
10nesne1
Silver - Posts: 284
Posted: December 10, 2002 at 1:33 PM / IP Logged
Dodge
Avenger
1995-2000
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ RED
IGNITION SWITCH HARNESS
Ignition  #1:
BLACK/ WHITE
Ignition #2:
BLUE/BLACK
Ignition  #3:
N/A
Accessory:
BLUE
Brake  Light:
GREEN (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE/ BROWN
AT POWERTRAIN CONTROL MODULE *
Parking Lights:
GREEN / WHITE (+)
18 PIN BLACK CONN. AT FUSE BLOCK
Headlights:
RED (-)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
GREEN / WHITE (-)
BLACK 20 PIN CONNECTOR
OEM Alarm  Arm:
GREEN/ YELLOW (-)
IN DRIVER'S KICK PANEL
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Powertrain Control Module (PCM) Located On Driver Side Fenderwell In Front Of Battery. WHITE/ BROWN Wire Located At Pin #73 In 80 Pin Connector At PCM.
Dodge
Avenger
1995-2000
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
WHITE
Starter  Kill:
BLACK/ RED
Ignition  +12 Volts:
BLACK/ WHITE
Dome  Lights/Superv:
RED / GREEN (-)
DRIVER KICK PANEL **
OEM Horn:
GREEN/ RED (-)
STEERING COLUMN HARNESS
Power  Lock:
BROWN / WHITE (-)
DRIVER KICK PANEL OR AT
Power  Unlock:
BROWN (-)
RELAYS BELOW RADIO ***
Trunk  Release:
N/A
Alarm  Input Wire:
RED / GREEN (-)
Notes:
** RED / GREEN (-) Wire Also Located In Black 19 Pin Connector On Back Of Fuse/Junction Block Behind Left Side Of Driver Dash. *** See Note #201 - Negative Pulse Door Lock Diagram.
Hope this would help.  Good luck.
