Posted: December 10, 2002 at 2:55 PM / IP Logged
Posted: December 10, 2002 at 10:27 PM / IP Logged
Posted: December 10, 2002 at 11:41 PM / IP Logged
Posted: December 17, 2002 at 9:42 PM / IP Logged
Posted: December 17, 2002 at 9:54 PM / IP Logged
Posted: December 18, 2002 at 12:56 PM / IP Logged
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
. When I spliced into them I've noticed that I don't have any A/C or heat! I know I made a stupid mistake by splicing into them, but the HUGE mistake I was told I did was cut them at the same time. By doing that it would short out that device. The wires it showed as the front left spkrs were Org/Lt.grn & Lt.blue/Wht. Well there was 3 sets of those wires. So I tried to splice the 1st set, spkrs didn't work. The 2nd set, spkrs didn't work still. So then I just said forget it and ran them through the door. Now I don't have the A/C or Heat. I've checked the fuses, A/C diode, but I don't know how to check if the relay is good. How do I do that? Also does anyone know what other fuses there are that run with what I'm talking about? I have air blowing at all speeds but on A/C its cooler, and heat it's like normal air. I'm thinking it 's the blend door, but how do I check that? HELP!!!!!!!!!!!
