95 Grand Prix wire diagram
flyguy91318
Posted: October 28, 2005 at 6:47 AM / IP Logged
Hey guys and Gals anyone out there have a wire diagram for a 95 grand prix I am going to be installing a alarm in would and It would be helpfull if anyone could help me out it would be appricated thanks
mo12v
Posted: October 28, 2005 at 7:47 AM / IP Logged
Constant 12 voltsRED / WHITE AND REDIGNITION SWITCH HARNESS
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightDARK BLUE (-)DRIVER KICK PANEL OR HEADLIGHT SW.
Trunk Pin SwitchN/ATRUNK HAS MERCURY SWITCH
Parking LampBROWN(+) AT HEADLIGHT SWITCH
Power LockLIGHT BLUEDRIVER KICK PANEL OR AT
Power UnlockWHITERELAYS IN PASSENGER KICK PANEL
Positive Pulse Door Locks
Accessories
Window UpD\ D BLU P\ L BLU D\ D GRN P\ L GRN @ MAIN SWITCH
Window DownF/ BRN F/ TAN R/ VIO
R/ VIO
Ign Key WarnLIGHT GREEN(-) STEERING COLUMN HARNESS
Trunk ReleaseBLACK/ WHITE(+) AT RELEASE SWITCH
OEM HornBLACK (-)STEERING COLUMN HARNESS OR AT RELAY
HeadlightsYELLOW(+) AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmN/A
Reversal Rest At Ground Power Window Circuit
Positive Pulse Trunk Release
Remote Start
Tach SignalPURPLE / WHITE OR WHITEAT IGNITION MODULE *
Ignition #2PURPLEIGNITION SWITCH HARNESS
Ignition #3ORANGEIGNITION SWITCH HARNESS
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyORANGE / BLACKAT CONVENIENCE CENTER **
Brake LightWHITE(+) AT SWITCH ON BRAKE PEDAL SUPPORT
Reverse LightLIGHT GREEN(+) AT SWITCH ON TRANSAXLE
Rear Window Defrost
* Ignition Module Location: 3.1L Earky Production on Rear Of Engine, Late Production On Front Of Engine. 3.4L On Front Of Engine. Follow Spark Plug Leads To Locate. ** Behind Driver Dash. Also Contains Chime Module (Follow Sound).
GM VATS System Standard On 1995 Models
MO
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
