Did I blow a fuse
kaikim
Posted: October 28, 2005 at 3:00 PM / IP Logged
I had to take out one of my rear neon lights, because it had cracked.  So I snipped the wire and removed the bulb.  I left the wire under the truck, and covered it with electrical tape.  This morning i go to turn it on, and none of my lights work.  I check the rear light wiring and see that there are small bits of wiring showing.  Did it blow my fuse?
KarTuneMan
Platinum - Posts: 7,056
Posted: October 28, 2005 at 3:36 PM / IP Logged
you more than likely blew the fuse when you cut the wire
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
