best amp for kicker solo x 18?
kingupfork
Posted: October 29, 2005 at 3:40 AM / IP Logged
Ok, i am pretty new to this i admit.
But what i am looking for is i plan on getting a kicker solo x 18". My guestion is what would be the best amp to fit this. I also have a guestion about electrical upgrading and how i would do that. Because i know for sure with this hooked up i woudent even be able to start the car.
Any help would be apprecaited thanks.
menace2sobriety
Silver - Posts: 394
Posted: October 29, 2005 at 4:44 AM / IP Logged
2 mtx T92001 amps strapped together for an rms power of 6000 watts and 2 1/0 guage cables.
and on heck of an alternator.  yes you will be able to start your car. just dont play it with the car off.
p.s. why do you want this set up?  this is spl territory. not everyday use. well you can but why??
Blowntweeters
Silver - Posts: 650
Posted: October 29, 2005 at 9:44 AM / IP Logged
there are a few amps. that will run that sub. i would suggest a soundstream XXX. your alternator is going to be you biggest need. what vehicle is this setup going in ?
1974 ford pinto 4 15" punch Z power punch bd 1001 pioneer DEH-6700
Alpine Guy
Platinum - Posts: 2,478
Posted: October 29, 2005 at 4:49 PM / IP Logged
Your going to need about a 400 amp alternator set up if you plan to run that set up properly, most likely 2 alternators. So you may have to loose your air conditioning to be able to run everything all fine and dandy, no if's and's or butts about it.
Reeceddogg
Copper - Posts: 331
Posted: October 29, 2005 at 7:24 PM / IP Logged
A guy at a local shop has one of them off two Colossus amps hitting around 159+ with the car off. the stock alternator but with the kinetik 2400 monster battery
dwarren
Posted: October 29, 2005 at 7:40 PM / IP Logged
Get an Arc 4000xxk. Then let me borrow it, forever
mylar
Member - Posts: 46
Posted: October 30, 2005 at 8:25 PM / IP Logged
After you get the alternator out of the way, I'd recomend 4 Kx2500.1s, strap them in pairs, and then wire the amps parallel to the sub
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
