05 Dodge Sprinter Door Lock Relays
nautix
Posted: November 03, 2005 at 8:22 PM / IP Logged
How would you wire the realys to switch? Cause if you wired them as just a neg trigger through a relay it would just would lock and un lock with one button on the remote.
any help would be appreciated
Heres wiring code from directechs
POWER LOCK       WHITE/ yellow       -       sw on dash or ctm, pink plug, pin 7                  Negative pulses on this wire will alternate between lock and unlock.The CTM (Central Timer Module) is under the driver seat. MUST USE RELAYS!
KarTuneMan
Platinum - Posts: 7,056
Posted: November 04, 2005 at 12:40 PM / IP Logged
Its a one wire lock system....is it not?
