04 Malibu
malibu04
Member - Posts: 40
Posted: November 04, 2005 at 1:21 PM / IP Logged
Ok.  Did a search and didn't find anything to promising.  Anyone done an amp on an 04 malibu sedan.  Has a dual firewall and was wondering where you ran the wire from(front fuse box or battery) and where the amp was mounted.  Also, how to take out the stereo to wire in the lead.  Thanx
malibu04
Member - Posts: 40
Posted: November 04, 2005 at 4:17 PM / IP Logged
sorry..i also needed to know where the wire went through the firewall
tcbturbosux
Copper - Posts: 69
Posted: November 04, 2005 at 5:33 PM / IP Logged
try the steering wheel boot. Or in the case of a 96' 300zx ...floor pan with split-loom and cable ties
                                     Gumby
Uncle Gumby
malibu04
Member - Posts: 40
Posted: November 05, 2005 at 1:36 AM / IP Logged
what is the floor pan and split looms?  Steering boot is a good idea since it is eletronic...thanx..will check it out tomorrow
tcbturbosux
Copper - Posts: 69
Posted: November 05, 2005 at 10:42 AM / IP Logged
the floor pan is the floor of the car .You should be able to find a spot under the carpet on the driver or passenger side to drill, make sure that there is nothing that you could damage on the under side of the car. Run your hot wire along the underside of the car and up into the engine compartment, be sure your wire is away from extreme heat producing components ; ie. exhaust, and all moving parts. If you have ever used any standard amplifier kit the black tubing that they give you is split loom. use the split loom around your wire from your drilling point to your battery. use cable ties and metal self tappers to attach the wire to the underside of the car. I hope I'm not confusing you. If  you need better explanation email me at  Amerisport@msn.com.
04 Malibu - Last Post -- posted image. Candy
Uncle Gumby
malibu04
Member - Posts: 40
Posted: November 06, 2005 at 8:14 AM / IP Logged
how do you get the stereo out? i need to beable to get to the lead
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
