Sprinter van
b1mmuo27
Member - Posts: 37
Posted: November 09, 2005 at 11:21 PM / IP Logged
Does anyone have a wiring diagram for the drivers door electric locks & central locking on a 2005 sprinter? Or does anyone have a 100% working alarm installed in keyless entry model working withe the keyless entry? Thanks
KarTuneMan
Platinum - Posts: 7,056
Absolute Audio
Member - Posts: 21
Posted: November 13, 2005 at 11:10 AM / IP Logged
you need to use 3 relays on the lock motor wires (all found under the drivers seat) i have done a few of them and it worked great.. the factory system uses drivers door priority and with a single wire locks system it can have a sync issue if you don't 5-wire.
good luck
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
