double pulse
muaiad97
Copper - Posts: 207
Posted: November 12, 2005 at 6:43 PM / IP Logged
hi everyone
whats   mean   double   pulse  and  how  to do it  is it in  the  car  or  in  the transmeter .
thanx
mo12v
Posted: November 12, 2005 at 6:52 PM / IP Logged
Double Pulse will be in the RKE or Keyless unit or a Pulse Generator
MO
muaiad97
Copper - Posts: 207
Posted: November 12, 2005 at 7:06 PM / IP Logged
i still   didnt  get it  whats mean
Chris Luongo
Platinum - Posts: 3,746
Posted: November 12, 2005 at 7:35 PM / IP Logged
If a tech sheet lists a wire as "double pulse," what that means is that in order to do what you want, the wire needs to be triggered twice.........that is, your alarm will need to send a ground to that wire in the car, then the ground should go away for a moment, and then come on again.
Most likely, you are talking about a door-unlock wire.
If the wiring sheet for your car lists the unlock wire as double pulse, make sure you buy an alarm that is capable of a double pulse output when unlocking.
As mo12v says, there is always a separate module you can buy that will take a single pulse in, and then put a double pulse out. But it is usually more economical (and easier) to just get the right alarm to begin with.
