2001 Dodge Stratus SE Sedan Wiring
matto02
Member - Posts: 9
Posted: November 13, 2005 at 2:37 AM / IP Logged
Can anybody help me find the wiring diagram for the 2001 Dodge Stratus SE Sedan.  I'm planning on wiring up a alarm system, the Crimestopper CS-2003DC Series 2.  Also if anybody has any other helpful information it would be greatly appreicated.
Thanks,
Matt
vans
Member - Posts: 14
Posted: November 16, 2005 at 12:27 AM / IP Logged
Dodge | | Stratus | | 2001 - 2002
Remote Starter Wiring Colors and Notes
FunctionVehicle ColorLocation
Start:YELLOW
Ignition #1:BLUEIGNITION SWITCH HARNESS
Ignition #2:BLUE/REDIGNITION SWITCH HARNESS
Ignition #3:N/A**
Accessory:BLUE/BLACKIGNITION SWITCH HARNESS
Brake Light:GREEN/ ORANGEAbove Brake Pedal Switch
Tach Signal:WHITE OR WHITE/ REDAT TEST CONNECTOR INSIDE FUSEBOX UNDERNEATH THE HOOD
Parking Lights:GREEN / WHITE OR PINK/BLACKDOWN LOW INSIDE OF THE DRIVER'S KICK PANEL
Headlights:ORANGE (-)AT HEADLIGHT RELAY UNDERNEATH THE HOOD
Diesel Glow Plug:N/A
Clutch Bypass Wire:N/A
Notes:* This Vehicle Is Equipped With A Transponder Theft System. Use Universal Alarm Bypass Module part number 2x402 where X can be any number. **All DesignTech remote starters except the 2xx22 have an ignition 3 output - it is the WHITE/ black in the "control
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts:WHITE/ REDIGNITION SWITCH HARNESS
OEM Alarm Disarm:DISARMS WITH UNLOCK
OEM Horn:LT. GREEN/ BLACK (-)STEERING COLUMN HARNESS
Power Lock:WHITE/ GREEN (+)AT THE BCM***
Power Unlock:WHITE/ GREEN (+)AT THE BCM***
Trunk Release:GREEN / WHITE (5-WIRE)DRIVER'S KICK PANEL LOCATED IN A WHITE # PIN PLUG
Alarm Input Wire:GREEN/ ORANGE (-)AT FUSE BOX IN A PLUG ON THE UPPER RIGHT SIDE
Notes:***Lock is positive through a 1800 ohm resistor, unlock is positive through a 750 ohm resistor.
