97 jeep cherokee, code alarm
jhend421
Member - Posts: 20
Posted: November 11, 2005 at 7:28 PM / IP Logged
Im going to try my first install on a 97 jeep cherokee. Im installing a code alarm ca-425a with a ca-645 remote start. Does anyone have the wire diagram for this truck and can you tell me how many relay's if any i will need for this truck?
James Henderson
cntrylvr79
Silver - Posts: 582
Posted: November 11, 2005 at 7:41 PM / IP Logged
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1997&make=Jeep&model=Cherokee&ID=18134&type=Alarm
There's you're diagram.  You will need 2 relays for the door locks even though this doesn't say you do.  Wire up as follows relay 1:  pin 85 to lock output of alarm.  pin 86 to constant +12volts.  pin 30 to ground.  pin 87 to the lock wire in the truck.  relay 2: pin 85 to unlock output of alarm.  pin 86 to constant +12volts.  pin 30 to ground.  pin 87 to the unlock wire in the truck.
If you have any more questions pm me, I've done quite a few alarm/start systems in these vehicles.
Cause I'm So white and nerdy...
First Class Certi-fried installer
jhend421
Member - Posts: 20
Posted: November 13, 2005 at 8:09 AM / IP Logged
I have a code alarm ca-425a/ ca-645 2way remote start system
1.  This system has a external start trigger, do i have to install this option and if i do to what wire will it be installed.
2.Do i have to use the manual arm input, armed output  and the manual disarm output wire's for this system?
3. The book say's i need a positive headlight hook up and the relay is set up different from the one on this sight to switch it to a positive output. 87-+12v, 87a-nothing, 86-+12v, 85-headlight output, 30-vehicle wire
James Henderson
mo12v
Posted: November 13, 2005 at 9:19 AM / IP Logged
1. = Only if you want to START the Vehicle with a NEGATIVE Pulse from another Source, like your Door locks, another Keyless / Alarm, etc.
2. = Only if you want to arm / Disarm Vehicle Factory Alarm or another Alarm.
3. = The Relay config. is correct, BUT, are you sure you want to hook up the HEADLIGHTS?
MO
jhend421
Member - Posts: 20
Posted: November 13, 2005 at 9:23 AM / IP Logged
Do i need to hook up the light's. I just figured it was needed since it was in the book? also for the accessory wires since i have only one accessory wire should i hook them both to the same wire and isolate both of them or just leave one unhooked?
James Henderson
mo12v
Posted: November 13, 2005 at 9:31 AM / IP Logged
Usually the Parking Lights are all that is necessary..........
As for the ACCESSORY wire/s.........If you only need 1 Accessory, don't hook up the 2nd one.
Are you sure you have ALL Ignitions wired ?
Is this a GRAND Cherokee or just Cherokee??
MO
jhend421
Member - Posts: 20
Posted: November 13, 2005 at 9:39 AM / IP Logged
I haven't done the install yet. Im doing the install today and i just wanted to make sure of the connection's before i install. I wanted to make sure of the accessory hook up since it has to accessory wire's for the alarm. Thanks alot for the help.. It's just a cherokee.
James Henderson
jhend421
Member - Posts: 20
Posted: November 13, 2005 at 8:40 PM / IP Logged
Does anyone now if there is a different colored wire for the door trigger. I have a 97 cherokee sport 4dr and i don't have a light under the dash. Im having problems finding a yellow wire fore the dome light and door trigger.
James Henderson
mo12v
Posted: November 13, 2005 at 8:42 PM / IP Logged
Dome LightYEL OR YEL/WHT (-)AT FUSE BLOCK OR AT COURTESY LIGHT
MO
Fullthrottle
Copper - Posts: 101
Posted: November 14, 2005 at 4:56 PM / IP Logged
Check under the drivers side kickpanel.
