Dome Light Supervision on 2000 F150?
Helf
Member - Posts: 16
Posted: November 14, 2005 at 10:45 AM / IP Logged
I am attempting to connect the dome light supervision on a 2000 F150 and had a few questions.
1.  Which wire do I use?
According to the wiring diagram, it has a positive dome supervision wire in the passenger kick panel and also negative door trigger wires.  Which one do I use?
2.  Do I need a relay?
From what I understand it is better to use a relay, as the negative trigger from the alarm is normally not strong enough to power the lights.
If anyone could let me know which set-up is better to use and what wires I need to connect to I would greatly appreciate it.  Thanks,
Jason
mo12v
Posted: November 14, 2005 at 2:56 PM / IP Logged
You will need a SPDT Relay:
PIN 87 = Constant 12 volt ( + )
PIN 87a = XX
PIN 30 = BLACK / Blue Wire in Vehicle
PIN 85 = Negative Dome Light Output from Unit
PIN 86 = Constant 12 volt ( + )
Dome LightBLACK/ L BLUE (+)DRIVER OR PASSENGER KICK PANEL
MO
Saturday, July 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
