Amp remote wire ?
Simple question.
I'm doing a little project and I need to know one thing.
Does the amp remote wire NEED a constant 12V [or a little higher?] to work. Or say will around 9-12 Be fine?
Thanks.
-Anderson
If your wondering as to what I'm doing I can post pics later, just that they are on my laptop and thats about 40km away... BUt I can have them up by tomorrow @ lunch.
Sorry for double post, can't edit :(
oxygen65 wrote:
Are you sure of that? I know amps pull varying amounts amperage from the remote, but I thought the voltage must remain at 12 volts.
it is not going to be a consistant 12 volts anyway, say that you have 4 subs runnin off 2 amps at a 1 ohm load without any upgrades to your alternator, battery, or having a cap. your cars voltage is going to drop down no matter what so it is not going to be a consistant 12 volts
I'm sorry for the above.
The forward voltage is < = 4.5
Sunday, April 5, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
