adding four 2 wire actuators
enwycee
Member - Posts: 6
Posted: November 15, 2005 at 9:25 AM / IP Logged
hi, i just purchased a keyless entry unit with 4 actuators on ebay. It has wires for unlock and lock outputs. How can I hook up all four actuators with these two wires? I was looking at the diagram for hooking up one actuator using 2 relays, thats fine.  but i have four actuators, so it says to connect them in parallel across the relays.... how can i do this?
schmoo
Copper - Posts: 62
Posted: November 15, 2005 at 11:31 AM / IP Logged
mount them in the doors, and run the wires to a central location.  Most likely up, under the dash. thenwire them together to create a two wire connection.  test to make sure they all work together ie. they all lock together.  reverse them as needed.
a true canadian eh!
spudric123
Posted: November 16, 2005 at 12:14 AM / IP Logged
No it works best if you wire them up as fire wire locks with a relay. by doing it this way you are able ensure they will work everytime and they will not have a problem. mount all of them and then run wires to the relay use the one five wire lock relay for all four actuators. this i know will work i do it a lot in the bay.
Spencer- Best Buy Mobile Install
schmoo
Copper - Posts: 62
Posted: November 16, 2005 at 8:44 AM / IP Logged
yeah, that's great when there is a 5 wire, but he said there are 4 2-wire actuators...
a true canadian eh!
rockycat
Posted: November 16, 2005 at 9:00 AM / IP Logged
Use the two relay setup for two wire actuators. Will work all four in parallel. Use good guage wire to the relays. Relay setup can be found under relays on this forum.
the12volt
Administrator - Posts: 3,957
Posted: November 16, 2005 at 9:06 AM / IP Logged
spudric123, while the relay configurations for 5 wire locks and actuators are practically identical, one relay alone would only lock or only unlock, not both.
enwycee, do as schmoo said, run all actuator leads to a central location and connect all the leads to the two leads labeled "to actuators" from the  two relays in the diagram below, reversing polarity on each set of actuator leads as necessary so they all lock and unlock together.
adding four 2 wire actuators -- posted image.
adding four 2 wire actuators -- posted image. the12volt • Support the12volt.com
enwycee
Member - Posts: 6
Posted: November 16, 2005 at 2:08 PM / IP Logged
so from each door, spilce each actuator wire together (blue to blue), (green to green) until you are at the relays? then connect them to pin 30 on relays? This will work fine with what gauge wire? I am using radio shack speaker wire, 18 ga., then splitting the two wires into one and using that one wire. It is the same thickness as the actuator wires. Thanks for the help all.
enwycee
Member - Posts: 6
Posted: December 08, 2005 at 10:07 AM / IP Logged
ok so i followed all of your instructions and now i wired all the door locks to a central location, leaving two wires from the actuators which i tested and it locks all four at the same time. Now I installed the keyless entry unit's wires to the appropriate pins on both relays. By the way it is an Autoloc unit KL 550. It has red for power and black for ground, and a blue/white wire for lock output and GREEN / WHITE for unlock. It also says to connect a ORANGE / blue and ORANGE / green to ground which i did. Now when i wired all the wires to the appropriate pins, it would not lock or unlock. I could feel the lock relay working but not the unlock. Is there another way i can wire it up? or use a "PCB latching relay"? how much for one of those?
forbidden
Platinum - Posts: 5,354
Posted: December 08, 2005 at 3:01 PM / IP Logged
By the sounds of it you bought a keyless entry unit that has internal built in relays. Verify this please.
Monday, November 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
