Turn signals spazing out
lewman78
Member - Posts: 10
Posted: November 17, 2005 at 10:43 AM / IP Logged
I know this happens to alot of cars because I see it all the time. On my 97 Ford escort my right trun signal blinks twice as fas as it should. Does any one know why this happens and if it is fixable? It is kind of embarrassing turning left when your turn signal is spazing out.
cntrylvr79
Silver - Posts: 582
Posted: November 17, 2005 at 10:50 AM / IP Logged
Have you checked the bulbs in you turn signals?  Most cars the turn signals start flashing really fast when one or more of the bulbs has gone bad.
Cause I'm So white and nerdy...
First Class Certi-fried installer
lewman78
Member - Posts: 10
Posted: November 18, 2005 at 8:19 AM / IP Logged
I know that they all light up if that is what you mean. I cna see the reflection off the car in front of me when thery are blinking.
infinkc
Copper - Posts: 438
Posted: November 18, 2005 at 8:38 AM / IP Logged
how about behind you
There are 10 types of people in the world, ones that understand binary and ones that dont.
brcidd
Copper - Posts: 274
Posted: November 18, 2005 at 11:07 AM / IP Logged
It has been my experience that too much load makes them flash faster- a burned out bulb will lessen the load- usuaaly make signals not flash at all- wheras a bulb that has the wrong resistance, an extra bulb, the wrong part number bulb will all create more resistance, or more load and cause the flasher to heat up faster, thus the rapid flashing rate-- check to see if someone has installed a bulb wrong, or the wrong part number bulb- in any of the sockets-  also this is why in the old days- when you hooked up a trailer- you always needed the "heavy -duty" flasher that kept the bulbs flashing normally....just my thoughts........
Brcidd - Engineer That Does Remote Starter Installs on the side.
extreme1
Silver - Posts: 1,070
Posted: November 18, 2005 at 11:25 AM / IP Logged
newer vehicles (90 and up let's say) use electronic flashers, and when they sense a lower load, they are designed flash quicker to indicate a fault in the system (IE bulb out).
the older vehicle would just come on solid with the old style mechanical flashers
Shaughn Murley
Visions Electronics
Red Deer, Alberta
lewman78
Member - Posts: 10
Posted: November 22, 2005 at 9:13 AM / IP Logged
I got out  and walked around the car. all the bulbs work. I bought the car off an old lady who use to tow it behind an RV. then I recently hooked up an alarm to it. When I hooked the alarm to the paarking lights, I used the pre-existing wires from when it was being towed. I think that might have some thing to do with it. I will check it out more closely this weekend, if it does not snow to bad.
