mtx 81000d question
shaggy_one469
Member - Posts: 27
Posted: November 17, 2005 at 5:36 PM / IP Logged
i am somewhat new to car audio and just bought an mtx 81000d and i have a question about this amp. i thought the amp is supposed to be mono but there is 2 channels. why? now i do know that it is bass amp only, but is that what mono means, bass only, instead of one channel? any help would be appreciated.
5150azn
Silver - Posts: 584
Posted: November 17, 2005 at 7:01 PM / IP Logged
It's mono on the inside. The speaker terminals you see are just split from 1 channel.
Tell the Snap-On guy I'm not here!
KarTuneMan
Platinum - Posts: 7,056
Posted: November 17, 2005 at 7:10 PM / IP Logged
Just makes it easier to hook up more than one driver to achive optimum loads......
shaggy_one469
Member - Posts: 27
Posted: November 17, 2005 at 7:33 PM / IP Logged
i apprciate it guys. also i'd like to know what capacitor would be best for this amp. i was told that 1 farad would be best and i was told that 1 farad would not be enough.
dwarren
Posted: November 17, 2005 at 7:37 PM / IP Logged
Don't bother with the cap. Do the big three under the hood, and consider a high output alternator.
youngone
Silver - Posts: 269
Posted: November 17, 2005 at 8:21 PM / IP Logged
if you dont no what the big 3 is do a search there is lots of info on this topic
Want to know some good equipment- JL,Adire Audio,Mcintosh,Brax,Helix,Eclipse,JBL,RE,Dimoand Audio,Zapco, pritty much anything DYhon,Forbidden recommend
On the12volt you give some info and you get in
shaggy_one469
Member - Posts: 27
Posted: November 17, 2005 at 8:49 PM / IP Logged
i appreciate the help.
shaggy_one469
Member - Posts: 27
Posted: November 20, 2005 at 11:43 PM / IP Logged
ok one more question (for now). ive got 2 audiobahn 12" svc, 4ohms. if i hook each sub up to each output, what impedence would it be? still 4ohms? also, how would i wire it to run 2ohms, as the amp is most powerful at 2ohms.
dwarren
Posted: November 20, 2005 at 11:55 PM / IP Logged
If you hook up one (4-ohm) speaker to each terminal the amp will still see a 2 ohm load. I know because that's how mine ismtx 81000d question - Last Post -- posted image.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
