no green light on the amp only red
kundi13
Member - Posts: 21
Posted: November 21, 2005 at 11:26 AM / IP Logged
hi, ive got 2x500watt spl subs and 500watt toxic 2channel amp bridgeable.  the sub and the amp works great when i play it indoors and the amp produces a green light (connected to a transformer). but when i connect it in the car the amp shows a protection bright red light and no sub works but everything else works fine so why doesnt it work in tha car???? thanks.
kundi
KarTuneMan
Platinum - Posts: 7,056
Posted: November 21, 2005 at 11:56 AM / IP Logged
Check the ground connection....first!   Is the turn on signal from your deck working? turn the deck on and check at the amp for voltage at the power connecter and the turn on connector.  Also, if you some how toasted one of your subs, that can open the flood gates on the amp and it will go into protect mode. Check the voice coils on the subs with a multi meter. Make sure you wired them correctly also!
DYohn
Platinum - Posts: 10,741
Posted: November 21, 2005 at 12:03 PM / IP Logged
Please don't post multiple threads with the same question, kundi13.
As stated in several responses, your problem is either bad wiring (power and/or ground,) too low impedence load, bad speaker wiring, a blown speaker, or too low voltage from your vehicle.
kundi13
Member - Posts: 21
Posted: November 21, 2005 at 1:00 PM / IP Logged
hi thanks for your replys. by the way when i play the sub indoors it dont connect to any decks because i dont have any lolz. i just connect using a transformer with plus and negative on it and connect it to a mp3 player and listen. but thanks. i try rewire it in the car again i mean like its total 1500watts im using which really aint that big is it so i dont think i be needing 2 batteries as it is a clio with a 12v battery. hopefully the red protection light can piss off and let the green light appear.
kundi
Sunday, January 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
