2002 dodge ram 2500 diesel wait to start
tcool
Copper - Posts: 100
Posted: November 21, 2005 at 10:55 PM / IP Logged
I need a diagram for an 02 dodge ram 2500 turbo diesel pickup. The tech sheets I've seen on here show that the wait to start wire is ORANGE / black in the top plug in the middle of the firewall for other years. There are 2 ORANGE / black wires, and neither of these test correctly. One works, and I am beginning to think it's staying on because it's so warm. I also see that in 03 dodge went to a multiplex system, and you need to use a pulse timer. Can anyone shed any light on this? Thanks.
bzzzzttttt
kimberley
Member - Posts: 10
Posted: November 22, 2005 at 6:36 PM / IP Logged
See DirectFax document 1090.
There are two black plugs, the wire is in the top plug without the white insert.
If using the ORANGE / black for wait to start causes a shifting or cruise control problem then use a pulse timer relay instead. Refer to DirectFax 1091 for wiring information.
dxdmi
