97' Pont Gr. Am remote starter&buld test
glm2002
Posted: November 22, 2005 at 3:26 PM / IP Logged
I have a 97' Pontiac Grand Am. I have a Rattler remote starter and a immobilizer bypass(1)  from bypasskit.com, the PLXR model, it says to hook up the voilet/white wire the the buld test. There illistrasion shows it hooked up to a (-) output, but the wire I found in the 6 pin black harness the thin black wire, reads a 0 volts in the off position, 12 volts in the run position, and 0 volts in the cranking position. I would to know if this is the correct wire? I had read somewhere that the bulb test wire is either an open ground, or grounded loop. Is either one of these correct or I'm way off base? I don't wish to hook the bypass and blow it up. I would appreciate any help.
chriswallace187
Gold - Posts: 1,661
Posted: November 22, 2005 at 3:50 PM / IP Logged
Assuming that wire is in the ignition harness with the heavy gauge ignition wires, it's the right wire. It's showing ground in the crank position, which is precisely what it should do.
C Renner's Auto Electronix
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
